Try getting someone with a PST2 to reset the codes - the Durametric tool is handy, but no replacement for the real deal...
-Wayne
Will resetting the fault ensure the module is working? I don't want to be in a situation where the airbags don't work...
-Wayne
Note: Fault codes 100 and higher are internal control module faults. The stored faults cannot be erased.
You need a new airbag controller.
-Wayne
Thanks Loren, that's what I figured...
OK new question. If I pickup a used airbag sensor (996.618.217.01 - same part # as what is in my car), do I just swap it out and all is good, or is there anything else? I read some post that the dealer will need to code it...
Thanks in advance!!!!
Chad
OK, I replaced the Airbag Sensor 996.618.219.01 and same problem. What's next?
Sorry, but if the code won't clear then you still have a problem and it may be in the wiring. Any sign of rodent damage?
I didn't see anything. I will have to look further. That might explain why the car sitting at the mechanic and then this. That harness runs from that module to the ECU I think?
  • 11 months later...
I have a 2001 Boxster 2.7 Tiptronic. Airbag fault codes:
-195 Unknown Code
-102 Unknown Code
-3 Power Supply
Dealer suggested replacing the airbag control unit. Also wondered the part number (US car) and if switching the part requires programming by the dealer, or if there are any DIY instructions. Dealer here quoted $900 for part & labour. Ebay has used ones on for $200...
David
-195 Unknown Code
-102 Unknown Code
-3 Power Supply
David
Sorry airbag fault codes > or = to 100 means the fault cannot be erased and the airbag triggering unit is faulty.
Try Sunset Imports (Porsche Parts at Dealer Cost) for better pricing.
