I need to remove the plastic grill from the rear spoiler to install an after market TA style wing. Any hints/instructions on how to remove the grill on a MY02 C2 Cab?
Ed
Ed
I did this recently, pretty much remove all the torx bolts you can get at and the 6 small longish bolts holding the acuator to it. Should not take more than 15 minutes.
Ed
Thanks for the response. Just to clarify, the torx bolts are accessed after removing the rubber plugs, where are the 6 small longish bolts? Really appreciate your help. Ed
Yes, pop the round plastic plugs out and you can get at them.
