In dash retrofitted cupholder install question
if anyone has done this mod would greatly appericate some instructions, lost the diagram that came with my cupholder while the parts waited to be installed.
help me clean out the parts bin that used to be my den!
Thanks! :P
Well I completed the job.....almost. It seems as though the black trim that surrounds the climate controls will not work. I've looked at pictures of cars with this install or PCM and it looks to be a totally different trim piece. oh well i guess Ill order it from my service center. Two notes for anyone thinking about this mod is that 1. the climate control will be mounted on the bottom, becomes obvious once the parts are....umm apart. and 2. if the two plastic clips that hold the cupholders "frame" in place arent very firmly mounted then youre wrong. took me an hour without instructions.
Also a I'm little bitter about the no help.
Edited by Buxmw
