Reving The Engine
emguy
Hi all,
I just got a new 997 GT3.....I used to have a Cerrera S and I remember that the owner's manula stated that one should not exceed 4500 rpm in the firts five minutes of driving....I have not seen the same warning on the Gt3 manual.....Does this rule or a similar apply to this car?
Thanks a lot
  • 4 months later...
There is probably a lot of fudge in there. They tell you 4200 because you will go past that sometimes and they want you to take it easy. You will probably hit 5K from time to time. If they told you 5K, you would hit 6K and so forth.
What is most important is getting as much break in time with the engine and systems warmed up. They really mean it when they tell you to take a few long trips. I took a 1,000 mile road trip the day after I got mine.. It was a pleasure.
Keep in mind that many systems need break in. The steering loosens up. The transmission does too - noticeably after 2K. You always need to baby the engine and tranny when cold - but especially during break in.
And get the car aligned. They are never spot on from the factory. Might as well do this after break in. The suspension may settle a touch and you will be taking it easy in the meantime...... RIGHT????
