Does anyone have any rwhp numbers for a stock 997S? With and without tiptronic?? I have some numbers for my slightly modified tip, but don't have stock rwhp numbers to compare with. Any help would be appreciated...
  • 6 months later...
On the various forums, I have seen stock rear wheel horsepower figures varying from 290 to 310 for the S model. There is, apparently, a high variation in results and repeatability from various dynamometers, which is also dependent on how the machine is operated. The car will need several pulls to adapt the ECU to maximum performance. Loss in the drivetrain is generally considered to be 16 to 17 percent for rear wheel drive, 20 percent for all wheel drive. It looks like if it wasn't done on the same dyno, same day, same operator and correctly, you can't compare numbers with any assurance of being right.
Thank you!
