You just need to undo the bolt that holds that attaches the belt to the floor at the outside lap belt position. I forget if there is a plastic cover on it or not but it is just a bolt. You can then thread the belt through the outside lap belt hole in the seat. I would not thread the belt through the shoulder harness hole unless you want to take your head off in an accident.
