Lost the odometer part of my Speedo recently. Any special 'tricks' I should be aware of trying disconnect the unit to send in for repair once I have it out of the dashboard? Thank you
Pull the clock out first (it is just pushed into the dash) to get access to back of speedo to unhook the connections.
Can't remember when the speedos went elctronic. If yours is mechanical you can fix it yourself. I nevver got a guage trim ring off cleanly, but it really doesn't show when pushed back into the rubber gasket.
North Hollywood has always done good work for me. Palo Alto has been recommended by others.
Let me know if you need their addresses.
I've also heard that resetting the trip odometer whilst driving it can damage the mechanism in the speedo head.
