Does anyone know why the climate control is always on? Even if I turn it off, when I startup my car again, it's turns back on. Is there a way to keep the air turned off? Thanks.
Turn the fan speed all the way down, then hit the button again. This
should turn it off. Hit the auto button to turn it back on.
Paul
What temperature do you have it set to and what is the outside temp ? The air is supposed to run all the time except in economy mode but I was told it does not work to well like that.
Sounds like a problem
