I need it for my apline dash.....please help many many thanks... :o
I had to take the reverse wire from the rear taillight, as NONE of the wires mentioned anywhere else actually did the trick (weren't switched with the reverse signal) on my 08 S..
I still havent found the VSS wire..
Just get a Soundgate CANPULSE4 - it will let you use your steering wheel controls AND provides the VSS/Speed sensor wire AND reverse wire.. only downside is that it runs $350.
-Brett
