How do you check the level of the front differential fluid and where do you fill it from? - I accidently drained some out when changing the oil for the first time....
Thanks in advance
Great - thank you. From that graphic what I started to drain was not the front differential fluid. Any idea what is in the reservoir in the attached image and where to check the level and fill?
A is the inspection/fill plug.
B is the drain plug.
Fill until it at the inspection plug level (just before it overflows).
  • 5 months later...
Getting at the fill plug is a real pain. I had to take a hex key out of it's socket ( or cut one if you don't have a hex socket set) and put a box end wrench around the hex to unscrew the plug.
