On a 2000 996 the window drop feature works correctly until you let go of the handle. Once you let go of either handle (inside or outside) the window pops up again. So you pull the handle and it drops, but you let go of the handle to close the door, and CRASH goes the window into the roof. I have done a search and did not find this particular problem. Any ideas?
The window thinks the door is closed all of the time because the door latch micro switch has issues and is acting like the door is closed and latched. The switch may be just dirty and stuck or may be defective.
