I have a CDR23 that I am planning to replace with the PCM unit. I noticed that there are two types available, one is 2.0 and the other is 2.1 (PCM II?). My questions are:
What is the difference between the two?
Can I use PCM 2.1 in MY04?
Do both support SIM cards?
Dan
Euro 2.0 supported SimCard, 2.1 in the US. No 04 US models supported phones.
You could put 2.1 in an 04 but it will be a hell of a job.
Dan
So can a Euro 2.0 be installed in o4 Cayenne and be able to use the SIM functionality?
Dan
Dan
If you mean in the USA the answer is no I dont think so.
Also FYI the phone prep kit was a bit of a joke as PAG had almost no solution, a proprietary plug and play cradle with specific cradles for certain phone types.
Dan
Dan
Thanks for the information. I will stay away from the built in phone support and will probably install a US Version of PCM 2.0. I will upload the details once done.
