Greetings: went to start the car and while it turns over with vigor, it will not start. It doesn't even "try" to fire, leading me to believe either fuel or ignition.
Getting error codes P1237 through 1241 which say: "Fuel injector, cylinder 1-6. Interuption" No other error codes found.
All fuses good and other system operations seem fine.
I did the fuel pump test per the shop manual and it pumps fine.
Any suggestions?
Thx,
GA
Unless you have a wiring harness problem - it looks like the DME.
That is depressing. I doubt it is the harness. Everything really looks fine. Unless anyone has any other suggestions, I will be taking it to the shop tomorrow. Thx, GA
This may sound like a bad joke, but it is not. How much gas you have? How old is it?
I studied the wiring diagrams last night and decided to try one more thing today. I plugged in a known good relay (horn) into the Ignition relay socket in the rear relay frame, and the car fired right up. (the horn and ignition relays are the same.) I then installed a relay from a spare harness I have here into the horn socket and I appear to be good to go.
Crisis averted.
Thanks all. GA
Hi Gator,
I'm having the same problem, and I removed the panel behind the rear seats in my MY2000 Cab, but I can't seem to find where the rear relays are. Any help would be greately appreciated! I'm stuck! Is it that I'm looking in the wrong place? Is the ignition relay in the front?
Kabir
Any suggestions?
Thx,
GA
fuse blown had same identical problem and codes. The fuse was blown the injector fuse in fuse panel row c #2 30amp
that should do it happy motoring.
