Hello,
Anyone knows the part # for the cables that connects the CDR210 to CDC-3, or where to find it?
Jose C.
B)
You can buy the cable from Porsche or Becker.
The cable sold by Porsche is the same as Becker except the Becker is longer, so we coil any excess cable up next to the battery. It is much cheaper buying the cable from Becker or from a Becker dealer. You need a Becker Silverstone cable for a model 2660 (6 disc) or 2630 (10) disc changer. The Becker part number I was given is 1184.709-276.
Thank you guys ,
that was very useful.
thanks again
jose B)
Buy it from BeckerUS. It is pretty easy to install. You can't use an ipod if you use port C on the radio...just in case you were going down that road soon.
Good Luck.
