i need info on that sensor (oil temp,...oil press ????) on my 996 c2 tip ,and part number if possible on seal or gasket, is it a common leak?,......things i need to know before fixing this .... thanks
Edited by sir16
Cam activator cover. Common to leak or sweat a little oil. Snug up 2 bolts and it may stop the leak.
already did and still sweat.... thank s for the info
Edited by sir16
