Hey there,
This is my first post, so be gentle..
Currently have ~33k on my '04 Cayenne S. Dealer tells me I've got 4mm left on front brake pads (about 7mm on the back), so I'll be needing to change them soon. No problem. He says drive it till the brake pad warning light comes on, then bring it in. He also tells me I need to change the rotors too - not that there's anything wrong with them - he says this is routine stuff that Porsche recommends. Looked in my owner's manual - can't find any mention of replacing rotors routinely. Anybody heard of this??
thanks.
I personally would change the pads before the light comes on.
Rotors are not uncommon to replace on big heavy vehicles. Before they are replaced they should be measured for remaining thickness (within spec?) and checked for cracks.
There is no blanket statement from Porsche about replacing brake rotors they always recommend the inspections I mention above.
Thanks, that's what I'm thinking. Why wait for trouble, eh? I did find some spec's for rotors posted already (I think it was you).
