Hey there,
My window regulator recently went bad, and I replace it with a unit I sourced cheap from a wrecked boxster. The window now drops the appropriate amount when I open and close th door, but there is a glitch. The one-touch operation does not send the window all the way to the top. Rather, when I activate this feature the window will go about 3/4 of the way up, then drop down about an inch or two. I then have to hold the button to make it go all the way up. It did this occassionally even before I replaced the regulator. Is there some sort of adjustment I'm missing? I've tried "resetting" the window stops by clycling through the up and down positions. Thanks, Scott.
