Is there any way to replace the various bits of the SAI system without removing the intake distributor? I have a flexible hose clamp remover and was able to replace the shut-off valve, but gave up trying to replace the change-over valve. Didn't try the check valve, but that looks like it would have been impossible as well. If my hand was any bigger I wouldn't have been able to replace even the shut-off valve. I figure I must be missing something...
I guess nobody knows... Good news is I didn't have to replace the electric change-over valve after all. Just replacing the shut-off valve seems to have fixed the problem.
