Need your opinion and help to the following, thanks in advance!
Purchased a 2000 C2 a week ago very low mileaqe (24k), looks brand new. So far love the drive.
1: The vehicle never came with the factory recommended maintenance book showing the oil change intervals etc.. I do have the owners manual. Is there a source to get the maintenance manual or chart?
2: Looking into changing out the gearshift and brake lever to a better looking one from CARNEWEL.com. How much time and effort is needed to do so.? Without really looking into it yet, does the center console have to come out.
3: Champion motors here in S Fla has the upgrade Litronic Xenon headlight kit for $1,300 their labor is $540 to install.
Does this seem to be high on the labor?
Edited by KevinMac
1. http://www.renntech.org/forums/index.php?a...=maint_menu_car
2. Yes, the center console will need to come out to change out the handbrake. Probably a little more than 1 hour for all the work.
3. You can install it yourself in less than an hour (with hooking up the high beam control units). Folks that don't hook up the control units can install the headlights in about 5 minutes (instructions are in your owners manual).
