Could someone please inform me what this part number corresponds to?
It is supposed to be a Mk1 Aerokit Side skirts. Is that correct?
I have found a used set of the side skirts and want to find out if that is the correct one. Anyone knows if i can get the hardware needed to fit these from Porsche or somewhere else, if they are not included?
Regards,
Nikos.
That part number is too short.
Perhaps you mean 996.559.980.01.G2X Right Aerokit Cup sideskirt.
You can buy the epoxy, and the various other small parts to attach them.
See the TSB called Aerokit Cup Installation (all the part numbers are there).
Hi Loren, i did read both TSB's (for both Aerokit Cup and Aerokit II kits) but i did not find that part number, and i noticed as you mention that it is not complete. The epoxy ant the other parts needed, do i get them from the Porsche Dealer? Can i also use two-sided tape as used for the aerokit II or not?
I am thinking whether to buy these or get the aerokit II side skirts which might be easier to fit to my car.
Regards,
Nikos.
