I would be worried about the corrosion effects on injectors, seals, etc. Have heard good things about tolulene though. Tolulene is the component that increases octane in gasoline.
More corrosive than gasoline and all the additives in it? Aceton burns very cleanly just like propane. Supposedly, fuel systems are designed to withstand any corrosive materials..
Mythbusters ran a test and concluded that acetone offered no benefit. Probably not conclusive, but at least it's a data point.
Toluene does look more promising.
Allen
That article seems like a lot of BS to me (I'm a biochemist, been working in the biotech industry for >20 years). This statement is a joke:
"Most fuel molecules are sluggish with respect to their natural frequency. Acetone has an inherent molecular vibration that "stirs up" the fuel molecules, to break the surface tension."
Yeah, right!
Agree with the other poster, acetone is a pretty agressive solvent, wouldn't want to test it on the seals in my P-car.
Also, use the reality check method. If adding acetone was such a great thing to improve mileage and reduce pollution, don't you think Shell and/or Chevron, etc would have figured this out some time ago?
we used to add toulene in the old days for qualiying, but had to flush it out quickly or it ate up rubber components in the fuel system. would not recc for street use. buy good gas or get av-gas
My experience with tolulene was with my prior car - 1990 Nissan 300ZX Twin Turbo. Adding the right amount of tolulene increseased the octane (never went above around 100). Could then use the boost controller to increase boost from the normal (with upgraded ECU) 14.5 pounds to just under 20. Tolulene is easy to find at many paint stores like Sherwin Williams.
Pjorgan - I agree, just like those devices that guarantee fuel savings by clamping on the fuel line and magnetically aligning the molecules! What a joke!
The only way to save fuel is to keep your car in top tune, and keep your foot out of it!
If anyone does use it, hope you don't spill it on your fender, bye bye paint!
Edited by KevinMac
