Okay so...
I have an 01 Boxster S RoW RHD with the cdr22, but I have no cd changer, can I just connect the ipod to the cd changer rca's or does the cd changer input only work when the other control cable is connected. I don't want to start leading cable into the cabin if it ain't gonna work!!!
Cheers
Johnny
Okay so...
Cheers
Johnny
check this out...
http://www.bombaydigital.com/boxster/projects/ipod/
I can't recall all the details, but I purchased a wire adapter that plugged into the back of the radio and to the iPod that would work perfectly. I don't think that RCA were even needed. $20-30. I didn't use it and returned it because I have a CD changer and would have to unplug the changer to plug in the iPod adapter.........I felt the changer was more valuable to me. I have an adapter in my other car for the iPod and I dont' drive the Boxster as much.
Go to Becker Auto Sound at www.beckerautosound.com. Here's a pdf that will assist you. http://www.beckerautosound.com/pdf_guides/...0directions.pdf
Good luck.
You can purchase a cable from Becker for $150 that will connect from dock of ipod to cd cahanger input on the cdr220 . This cable will also power the ipod (switched with Ignition) . Expensive since it is designed for Ferrari and hence Ferrari pricing!
Alternatively you can buy a cable from PIE see link (http://www.discountcarstereo.com/detail.aspx?ID=993) which will require its own power supply . See my posts (Tagger since I am ready to publish a Phd on this subject!) regarding some of the headaches I am having with this set up!!! It has been done without problems by others. In this case you will need to buy another cable from Becker to connect power via the accessory telephone cable.
If this does not make sense please feel free to message me. Thanks
The alternative is to look for a "Blaupunkt Apple iPod Interface" This cable has the same connectors as previous poster but has some intelligence in an electronic circuit. You can drive the iPod like a cd changer from the CDR-220
The Blaupunkt is compatible with all Beckers.
Here's one on the european Ebay: http://cgi.benl.ebay.be/APPLE-IPOD-INTERFA...1QQcmdZViewItem
And it will charge your ipod as well.
Edited by Koen De Poorter
I looked up my original correspondence wiht Becker Auto Sound.....
Is the BNA - 1319 - 116 the part needed to connect an MP3 player to a CR220?
Bob
Yes it is the kit. It comes with L and R female RCA inputs . You need to get male RCA to mini (3.5mm) plug adaptor.
The kit is $17.00
Tom Mitchell (of Becker)
Note...this kit will not power the iPod. But for $17 plus shipping, bring the iPod into the house to charge it up, or use an auto charger.
Okay so...
Cheers
Johnny
I think it needs to have the cd changer there and powered up for it to work. I have heard that it doesn't work if there is no cd in the changer but I haven't tried it without a cd in there yet. I leave in one cd and the changer thinks it is palying it, it even says says it's playing "track 5" etc., when listening to iphone/ipod via the cd changer rca cable.
