Hello all! I'm new to this site so forgive me if this topic has been covered! I have a PCM2 system in my car and the telephone periodically cuts out and goes through the whole resyncing process with the phonebook. Has anyone had this problem.? I'm thinking that it might be a sim card detection issue but the phone sometimes cuts out on a very smooth road, so not so sure about that theory! Sorry the topic isn't a little more interesting!! Any help appreciated.
A loose ground wire is usually the culprit. Check all connections. If not, then disconnect you battery for 10 minutes and resync your phone offsite. If not, then you have a compatability issue.
