Just got my car back from the body shop (local dealer authorized) from getting the aero kit installed and on the way home I decided to drop the top and enjoy the great weather out here in LV. HOWEVER.......the top does not go down.
Here is the scenario. Key in ignition, all lights light up including PARK.....then lights go out after check..........Engage parking brake to lower top.......Parking brake engaged (car stops rolling) but PARK does not illuminate on the dash......as well top will not operate. :censored:
Any thoughts before I take it to the dealer? I really don't want to have to go to the dealer for someting that I hope is minor.
Frustrated in Vegas,
Dell
I suggest checking fuse D3 first (fourth row down - 3rd fuse from the left).
Did they have the console out for anything? There is a microswitch on the hand brake.
To the best of my knowledge they didn't. But then again, who knows what goes on in the shop :o
I will go check the fuse right now. Could the battery have anything to do with it? (i.e., missed a step of some sort when disconnecting the battery).
Be right back. Thank Loren.
Dell
Fuse checks out. As does all the rest of the fuses :D Guess it is time to run by the dealer. Darnit, I hate that place. Any late minute advice before I venture to places unknown?
Car is at the dealership as we speak. Should know/have it fixed in the next coupe of hours. I am amazed that were able to squeze me in on a 1/2 day. We may be topless by lunch!
Also, make sure you can operate the top with the key in the door. You never know! :)
Good one Don. I never thought of that one even though I do the key trick sometimes. Anyway, in and out of the dealership this afternoon in a couple hours. Result...........just as Loren predicted--the handbrake switch.
Driving Topless,:jump:
Dell
  • 9 months later...
Hi all, first of all I love this site! What a great resource!
Second of all, Dell, I am in Las Vegas too, and I am suffering from your exact cab top problem. I had a big relief when I was able to open the top by using my key. However, when I pull the handbrake all the way up, the handbrake light does NOT come on the dash.
I did a search, so is this what is known as the handbrake swith fix? What exactly is that? Is it a fuse or something more involved?
Dell, what did Gaudin Porsche charge you to do this? Is this something I could do myself if I had the part?? I must warn you all I am VERY technically uninclined. :(
Thanks all and a belated Happy New Year to all.
Loren or anybody else, any information on this handbrake sensor or the situation as described above?
Thank you all!
Does your hand brake light come on in the intrument cluster when you apply it?
If not then the switch is not functioning and needs to be replaced. To replace the switch you will need to remove (at least partially) the center console.
George, sorry to take so long to get back to you. Just PM or email me in the future since I didn't get an email notification on this thread.
As for the switch, it was covered under warranty so I wouldn't know what they would have charged. However, this would have been a fairly simple DIY since I have already mastered the art of removing the rear center console :)
WELCOME TO THE BOARD!!!
Cheers,
Dell
  • 4 weeks later...
Work has been overwhelming as of late, so I am finally focusing on obtaining the correct switch and getting my cab top "fixed". I have searched Pelican Parts, but coming up short with respect to a Part # for the handbrake micro switch.
Does anybody have this information? I have a 2000 996 C4 cab.
-George
No problem. FYI...I just checked out the warranty write-up for my switch replacement. They indicated 1.5 hours of labor. Very easy to do yourself if you don't feel like paying out that kinda cash for a switch replacment.
Replaced mine myself. Under $10 part, and SIMPLE. The only hassle is removing the console, but that is fairly easy as well (just time consuming).
Now this is weird guys........
I ordered and received the part, and was planning an attempt on a DIY for the following weekend. In the meantime, I took my car to the dealer for it's 45K service.
I get the car back last Friday, and when I pulled up the handrake, the parking sensor illuminates on the dash. I made no mention of this during my service trip. The next day, it doesn't work. Somebody told me to pull up and down on it a few times to see if that helps. Well, it did. Now, it works perfectly, WITHOUT replacing the switch. I have tried it 20+ times over the last few days LOL.
Bad connection maybe? I would still take out the console and make sure it is connected nice and proper. Heck, if you have the new part and have paid for it you might as well install the new microswitch.
