I've removed the old ignition switch/steering lock mechanism from my '02 996 Carrera. This was so I could replace it with the upgraded model. Replacing just the ignition switch in the back didn't fully solve the problem.
Anyway, my last remaining task is to remove the ignition key cylinder from the old part so that I can put it into the new one.
How do you do that?
I read somewhere that you turn the key to position 1, stick a straightened paper clip into the little hole (the one on the upper right of the key in the silver ring surrounding the key) as far as it will go and that will supposedly free the cylinder to be pulled straight out. That's not working for me...
I'm trying to understand three things: what is the correct procedure, how far is the paper clip supposed to go in, and what are you supposed to 'feel' when you do it right?
Some notes:
--In position 1, the paper clip won't go in at all
--In position 2 (or in the 'starting' position as well), the paper clip will go in about 1-1/4", but it doesn't feel like it's actually depressing anything that would free the lock.
--I've already detached everything else--ignition switch, wires, etc.--so if those are supposed to be attached when I do this, please let me know.
Thanks for any advice.
From the manual...
Removal
1. Disconnect battery ground cable.
2. Pull cover (collar) off the steering lock.
3. Insert ignition key and turn to position 1 (ignition on).
Insert a steel wire with a diameter of approx. 1.3 mm (max. 1.5 mm 0) into the bore next to the ignition key (arrow) as far as it will go.
Pull the lock barrel with induction coil out of the steering lock housing.
Note:
Inserting the steel wire unlocks the lock barrel in the steering lock housing.
4. Carefully unlock and separate the plug connection on the lock barrel (at the induction coil for the immobilizer).
Loren, thanks as always. It works.
One note for anyone who stumbles across this post in the future...
The little silver 'beauty ring' around the key hole can get turned 180 degrees; at least it was in my car. So the hole into which you stick the paper clip was up at the ~1 o'clock postiion instead of ~7 o'clock where it should be. That completely explains why my prior efforts in this post weren't working. After figuring out this little nugget of knowledge (some number of hours into the effort...) and following the info above, the cylinder just falls out.
Once it's out, leave the paper clip in until you put the cylinder back in. Push the cylinder in firmly, pull the paper clip, and it should be in there just right.
One other thing...use your valet key instead of your remote key. The slim head makes it a lot easier to work around.
  • 11 years later...
I can not get the ring to move, the small hole is at 2 o’clock. I can insert the paper clip all the way, but the key will not turn past straight up and the ignition will not come out. Please help...
