Hi all,
If I move my 2008 Cayenne S (bought in USA) car to europe, do you think the navigation will work there (assuming that I buy the european DVD Disk)?
Any help would be great!
Brgs,
DNenes
With the PIWIS tester aprox. 15 minutes of labour, i don't no the charge for the tester if there is a charge.
  • 3 years later...
I know this thread is a bit old...but I am running into the same problem. Brought my US-spec 2009 Cayenne to Belgium and would like to get the PCM 3.0 NAV updated for Europe. Local dealers are saying that I have to buy a new PCM system, etc. which sounds totally incorrect. How can I explain to them that I need a new NAV DVD and a PCM re-code??
Thanks in advance!!
2009 and 2008 are different cases. PCM3.0 on 2009 has to be recoded with a code from Porsche and NAV reinstalled (there is no DVD there, it is Hard Drive based system). Porsche now either refuses to give a code or charges silly prices. I got mine done for Euro800 but that one was one first cars. things got worse since then.
It doesnt require new PCM and you can tell your dealer that at at best he doesnt know what he is talking about.
Edited by SA321
Excellent, thank you for the insight on the PCM 3.0 vs. 2008 and older models. So with this in mind, can I order a Euro NAV update (DVD loaded to hard drive?) from the States and have the update done at a European dealer, or would I typically have to purchase the Euro NAV update from a dealer in Europe and have them install to the hard drive?
And do you have any dealers to recommend in either Belgium (preferred) or Germany that can accomplish the NAV change? I don't mind driving a bit to get the best service.
Thanks!!
Thanks!!
Thanks again for the advice...have an appointment with a local Belgian Porsche dealer who says this should be no problem (after getting the PIN from Porsche to make the change and a bit of explanation). Will report back once it is complete and I find out how much $$ this will cost.
Regards,
Thanks for all the advice...was able to square it away with Porsche Headquarters and have the latest Euro NAV update installed on the PCM 3.0 via a local Belgian Porsche dealer. Cost was about Euro 450 for parts and labor-- not too bad!
Cheers,
Smittycat
