Hi everyone, I'm new around here, and I recently purchased a 2002 911 Turbo. The cowl cover seems to be having issues on the main screw supports on both the driver and pass sides. The passenger side one is broken, and the drivers side one is cracked and about to be broken. I'm putting a bit of epoxy on it, and I think they should hold, but am curious if anyone else has had similar problems, or is it just my luck? I couldn't find any info while searching for cowl cover stuff...is that even the real name of it? (This is the cover that goes between the hood and the windshield).
Thanks in advance,
Ben
Los Gatos, CA
Sounds like just your luck, but i have same same kind of luck too!! I reckon that they have been damaged/broken on replacement of the windscreen as this part has to come off i believe?? There is a link in the 996 Carrera section to workshop manuals, find the one with the windscreen in it and you'll see what i mean.....
