Sorry to bother you, but the folks on the threads at 986forum.com suggested that somebody here might be able to provide me the code to reactivate my 1999 Boxster radio. I had to take the battery to perform some service, and the radio now wants the code. I bought the car used, and I don't have the original owner's manual or radio code card. When I depress and hold the the TP button and scroll with the tuning knob, I find what I believe is a serial number of X5017877. If there is somebody here who can help me with the code to enter to reactivate the radio, I would appreciate it.
Thanks.
Bob
Loren,
Will 0147 or 0149 (from the blchambray thread "another lost radio code") work for any Becker radio in a 1999 Boxster? My serial number is X5017877, and I don't want to go through the 1-hour "wait" again if I enter the wrong code.
Thanks.
Bob
Edited by simbob
Loren,
Thanks. I'll try the suggested numbers this evening before I drive home from work.
This looks like a great site, and I plan to contribute to keeping it going.
Now I need to figure out why my floor carpet padding gets wet when it rains even though I know that all of the drains (3 front, two in each door and four rear) are clear and all of the top and window seals are intact and mating properly. I suspect a possible breach in the top well drip pan, probably in the forward corners behind the seats.
It wouldn't be a Porsche if it wasn't a project to own and operate -- it's a good thing they go, turn and stop as well as they do.
Thanks again.
Bob
Loren,
After my wait period expired, the car went back to "PORSCHE" with the sound of power going to the speakers when I turn on the ignition, followed by "CODE ****".
I entered 2845 with the preset numbers. Nothing.
I entered 2847. Nothing.
I entered each number followed by TP. Nothing.
I entered each number followed by the down arrow. Nothing.
I have tried every combination of the suggested numbers with all of the buttons and knobs -- entering each of the numbers followed by pushing each of the other knobs and buttons, and then pushing each of the other knobs and buttons before entering the numbers.
Nothing.
I can't even get it to tell me to wait now, even when I randomly push numbers and buttons.
Depressing and holding the TP button also does nothing now.
What have I done? What should I do? Is there a procedure for entering the code which I did not follow correctly? Is there another procedure I must follow now to correct my previous error? I have checked the other threads and posts about lost radio codes, and I can't find answers to these questions.
Thanks.
Bob
1999 US Spec Boxster
WP0CA2985XU628976
Radio -- CDR-220
SN -- X5017877
If you try several times in a row the system locks you out for 1 hour.
If the numbers I gave do hot work then you will likely need to contact a dealer or Becker. Becker charges to look up your code and so do some dealers.
