Hi today had my 2000 996 C4 throw P1125 and P1132 while turning on the ABS and PMS lights, not at same time.
Just to make it easy here it is:
1. P1125 and P1132 codes
2. In 5th gear above 5000 rpm PSM and ABS lights come on, can reset but as soon as I repeat it happens again..
3. Is this a bad MAF?
What I have done
1. Cleared OBD Codes
2. Replaced MAF
Do I need to do anything else?
Sorry is on the 986 side should be a 996, not sure what I did wrong
Edited by rountreed
What I have done
2. Replaced MAF
Yes definitely your MAF device. I had same symptoms on my 996 C4 when accelerating hard and fault was confirmed by OPC diagnostic lap top. New MAF fixed problem.
