Nothing in the spares on the drivers side fusebox ? I cannot test without opening the door and setting the accessory start up sequence.
I would rather not move under the seat is I can avoid it
Mike
ut the
Look for a phone prep plug (similar to the 986/996) under the passenger seat or in the center console - depending on your options.
Thanks Loren
Do you also know which fuse provides power to the rear CD Changer circuit ?
Mike
The phone prep goes to two fuse on the right fuse box.
