I'm going to mod my 3.6 cans
The mod is the one with a 2,25" stainless steel tube. I'm going to get them welded by a welding shop. They work very good.
My question is if anyone could do this mod welding electrical valves (connected by wiring to a switch) to cut out the bypass, similar to OEM PSE.
OEM PSE:
Mod without valves:
I have been researching this kind of mod myself and one big problem I have found is that these flaps are typically used to bypass an early part of the exahust that has a bigger pipe. On my Boxster the pipes leading into the muffler are a measly 1.75" which is much smaller than any of the bypass valves I have seen. The smallest I have seen is 2.25". It might be bigger on the Carrera.
One thing you can Google is "exhaust cutout".
And if I would learn how to read I would know that your bypass pipes are 2.25" so you are golden. Yikes, tough Monday.
