I would like to add an MP3 source of music to my 2003 986 S that has the PCM2 with the navigation. It doesn't have the CD changer option, and I haven't been able to find out if the CDC-4 can even play home burned CDs in the MP3 format. I have looked into the Dension Gateway 500 which is pricey, but not much that much more then the Becker built changer once you add mounts and cables.
Any advice as far as pros/cons would be great!
Matthew
