Hi everyone
what year cars was PSM introduced and can it be retro fitted
i understand it will be hard and expensive but if you wanted to do it can it be done and what would need to be changed
Hi everyone
Anything can be done if you have the parts, skills and the tools !
PSM takes it's inputs from the ABS sensors, steering rack and egas throttle - so a retro fit would need egas for sure. PSM will also need the brake line plumbing (as each wheel can be individually braked) as well as the electrical brain + all the looms.
I think PSM came about in the C4 first (1998/1999) then in the first egas C2's (2000?)
A LOT of work - just sell the car and get one with PSM ... it'll cost a lot less in the long run ... ;)
