Is the M030 suspension worth the money? It appears to be about the same price as the PSS9. Are the swaybars a good addition. How much will M030 lower the car? I really appreciate the feedback (this is a 1st time post) Thanks
Your question is really to simple. There are many M030 options of varying height. There is also the x74 kit from Porsche that you should consider. The Porsche kits all come with swaybars and they are an important part of upgrading the suspension. The PSS9 does not come with swaybars and you would need to source them elsewhere as well as find new end links for the swaybars. With PSS9 you will also have to have your ride height adjusted and the car corner balanced leading to higher install costs.
Do some more searches on the US M030 and ROW M030 as well as the x74 kit. Look here as well: http://www.forums.rennlist.com
