CEL, Durametric says misfire cyl 2 replaced #2 coil pack.. problem clears.. 200 miles and 1 track day later,
CEL .....Durametric now says misfire cyl 1 and 5. Whats the general rule with 50 K mi. and many track days. when 1 coil goes bad should I expect more going bad??
is it a good idea to replace the rest??
Replace all is the best you can do, they go's bad anyway. Cayenne have the same problem.
Definitely replace all of them. It's not a big job, but a fiddly one, and coil packs aren't too expensive.
Thanks thats what I decided to do.. They're only $40 bucks apiece..
Here (UK) they're the equivalent of US$50 each (independently sourced) and I described that as not "too expensive". Given the fact that replacing the coil packs is a fiddle, it's a no-brainer. Do the plugs at the same time.
