Update on my own question. I found that there are snap clips on the cable to set the pre-tension/slack of the cable on the regulator. While installing the regulator, one of the clips dropped out, resulting in too much slack. I clipped it back to set more pre-tension, and the window drops enough to clear the door trim.
Cheers!
Strange thing too is that after renewing the window regulator, the window still doesn't drop far enough to clear the outside rubber sill. When I pull either the outside or inside door handles slowly, I hear the switches activate the window relay before the door is released, and the window drops, but not enough. This is why I changed the regulators, but it seems that it's still the same. I'm puzzled.
Can anyone help?
