Can anyone please tell me how we can put a shift light in the dash or external of the dash; that does not require another instrument [besides the light-not another tach.]
Maybe a simple pin out, off of the fuse block. If I knew which fuse activated at maximum RPM, I could [might] figure out the light.
Maybe a 12V light activation for some signal to the ECU if it was tapped that would not create a grounding effect. I do not want to alter an ECU reading or incur a possible ECU burn out.
I hate hitting the Rev limiter and finding out the hard way...
I hope I made sense...
Thanks to all, ahead of time..... :clapping:
Check this out...
http://raptorperformance.com/
I just found a link to this on another board. I dunno how to make it work on Pcars, but on BMW, the RPM signal is available on the OBD connector. Maybe Loren knows the pinout of this connector.
-Scott
a lot of companies make shift lights for cars. you have to purchase one according to the correct amount of cylinders in your engine. i.e. they sell one for the 4 cylinder, 6 cylinder, and 8 cylinder cars. Autometer makes a nice shift light. You can buy the really small ones which are bright but not too noticeably when not on. they also come with covers to cover the lights so you're not always blinded when driving. some of them come with different plugs that allow you to change the time the light comes on etc... others have a knob at the rear.
To install, you remove your gauge cluster and find the ignition coil wire. or you can get to it from the distributor cap or from the ecu area if you know the correct wire. i'm sure someone on here can point you to that wire. then you just splice into it. if you know where the wire is and you are pretty handy with cars I would say it's about a 30 minute to 1hour job.
have fun and post pics~
I guess by the response, :huh:  either it was not a good idea or there is not a "simple idea" available.
Thanks anyway
I think your conclusion is correct. It is not needed.
I believe that is subjective, and not a given. I just wanted help :help:
My previous entry was only meant to be polite, and to draw help, and not opinions. :soapbox:
I'm going to install a Rev-Lite in my Boxster. I like these better than the single LED shift lights.
http://www.rev-lite.com/rev.html
While not completely necessary to drive fast, I'm still curious to see what it does in terms of being aware of what the engine is doing. I asked my mechanic this weekend if it would be easy to put in, he was like yeah, no problem. (We were both driving at Sebring this weekend at a PCA event)
Tom
I know this topic is OLD, but... I need to know what color the wire is for a 1997 986. 986.exe PDF program is on a computer that is not working right now. I dont have the printed factory manuals.
Help please.
B
Tom
So........is there something on this Rev-lite link I'm not seeing?
Here's another SPAC Design
The 1998-02 Boxsters use a Violet with Green stripe. It is in the white connector on the back of the dash. We installed a AutoMeter pencil style light.
Pics to come.
B
