Hello everyone,
I'm considering installing a Gentex 50-GENK50 (Auto dimming, Homelink, Compass, Temp) in my 2003 Boxster S, although most websites state that they "can not" or are "not recommended" for installs into any Porsche. I've called & emailed, but haven't received any definitive answer yet as to why. I'm sure someone out there either knows the answer why not or has overcome the the *reason* why not. :rolleyes:
I'm willing to get a little ghetto and install a second mount if needed, but I'm also willing to consider carving up my driver's side sunvisor and buying a Homelink transceiver from a local junkyard for $30.
Thanks for any insight in advance.
  • 6 months later...
I'm considering installing a Gentex 50-GENK50 (Auto dimming, Homelink, Compass, Temp)....
I'm willing to get a little ghetto and install a second mount if needed, but I'm also willing to consider carving up my driver's side sunvisor and buying a Homelink transceiver from a local junkyard for $30. Thanks for any insight in advance.
The Targatop switch in a blank switch location and a donor remote are a simple and clean fix for garage door openers. It has been a well-documented mod.
Just search a bit on garage door openers.
