Everything is back together with the exception of the security rosette on top of the dash. If I remember correctly, it required a good deal of force to free it from the surrounding pieces when I first removed it. When replacing it, it seems to not lock into place or needs a bit of leverage to seat it back onto the securing clips. I rechecked all the pieces and all the clips are still intact. Please let me know if you might have had a similar experience. Tnx
Yes, it just snaps back in. If you had the defroster trim out also, then it needs to go in first. Also, make sure the defroster trim is aligned towards the doors so that it does not conflict with the alarm sensor cover.
