A few weeks ago I replaced my Oil separator with the new updated version on my 2.5L Boxster with 90k on it (proud daily driver). I also replaced the J-Tube (thanks to Mike Focke!), but afterwards the car was still running bad - black smoke (especially at higher rpm's) and when I stop to accalerate (driving with constant speed) the engine is stuttering. At my service station they replaced the sort of EGR valve (cut-off valve), cause they thought it is a secondary air problem - it didn't changed a thing.
Yesterday I wanted to clean the throttle body and I noticed the new J-Tube from the AOS is full with oil again!!! Does anyone has an idea what's wrong with my car?
I still have engine failure codes from all O2 sensors and a lot of missfires on both banks. I think my entire system runs too lean and that's why the engine get's sometimes too much fuel injected (black smoke). I checked the car for secondary air leakages and already replaced the MAF....
1998 Boxster, 2.5L, 5-Speed, 90.000 miles
It's normal to have some oil in the J tube. Don't drive the car if the check engine light is flashing. Can you list the engine codes. To my knowledge your car doesn't have a EGR valve.... maybe best to start by finding another garage to have a look at it.
I know- it was not the EGR- they replaced the Air Pump Valve (993.113.250.03).
To find another garage here in Michigan is not so easy - most of them have not really experience with the Boxster, so they just start to replace one part after the other... To replace the entire engine would be way cheaper I guess.
Here is my "best of" failure codes:
27 OXS sensing range 1, Cyl 1-3, P1123 or P1124
34 OXS sensing range 2, Cyl 4-6, P1129 or P1130
10 OXS Sensor before cat cyl 1-3, P0130, 0134, 0131, 0132 *
18 OXS Sensor before cat cyl 4-6, P0150, 0154, 0151, 0152 *
26 OXS sensing range 2, cyl 1-3. *
55 Misfire Cyl 6 emission related, P1318
53 Misfire Cyl 4 emission related, P1316 *
54 Misfire Cyl 5 emission related, P1317 *
62 Misfire Cyl 5 emission related, P1319 *
The codes marked with a * returned.
I just checked all my documents and when I had the trouble with my MAF I had similar codes. I will clean my MAF tomorrow- maybe that helps, allthough I don't think so it is just 3 months old and at that time I never had black smoke...
That would say that the mixture on cylinders 1-3 is too rich (and the DME can not lean it enough) and your misfires and your O2 sensor on the cylinder 4-6 side is shorted (or reading a very high voltage).
I would find a shop with some good OBD II software and have them read the MAF air flow and TRA\FRA values so you can really see what is going on.
cleaned the MAF today and afterwards cleared the computer. Nothing changed - CEL came back on, engine is stuttering and black smoke comes after 3000rpms. Is there a way to check my O2 sensors? How do I know that my cat is still working?
Edited by JP986
I replaced the two pre-cat oxygen sensors. The car runs perfect now- no gas smell, engine stuttering or black smoke anymore. After 40 miles the engine check light came back on (P0130), I assume it is due to the dirt and carb which is still in the engine. I added some Techron (Chevron) engine cleaner to the fuel and fired the engine with high rpms on the highway to get it hot and clean- seems to work! So far (140miles) the light didn't came back on.
