Can anyone confirm that all porsche paint has a thickness reading of 4.5?
So, if the car has been repainted, it would have a higher reading.
Would the paint meter be a good way to decide if I should buy the used Cayenne?
Can a porsche tech guy be able to tell if the frame has been damaged? Or is that pretty much impossible.
Any competent body shop can generally tell if a car (Porsche or not) has been involved in a major collision that reults in frame damage.
A "repaint" would not necessarily result in higher thickness readings. A proper repaint involves sanding down the finish, which will remove several mils of thickness before re-applying either color coat and clear coat(s) or primer, primer-surfacer, sealer, then color coat and clear coat(s).
A paint meter can be a useful tool, but I would not rely on it exclusively.
Regards, Maurice.
