Have the code and entered it (after new battery install - Duralast 48-DL, fyi), but got the ol' WAIT message.
Question: if previous owner changed/reprogrammed the code, am I hosed?
Or should the original code (in factory manual) always work/unlock the radio? Finally, any help/ideas on what to do since it doesn't appear to unlock mine.
On my 996TT it shows that wait message with a timer that only moves when the switch is turned on, if you turn the car off the timer doesnt move and doesnt run out
We need to know your model and model of your car - plus the radio model (CR-210, CDR-220, CDR-23, etc.) to help...
CDR-210 in a 1999 996, BE 2282. I found 'another' radio card in my docs - different serial number. Will try that code if I can ever get out of the 'WAIT' loop. If true that car must be on to time-down, I need to drive it. I don't have a timer on my display, just the WAIT message. (My isn't TT, it's a 996 Carrera.)
Yes, a good number of MY99, 00, and 01 cars had their radio replaced for peeling buttons.
Mine was replaced too - I should throw away my old radio code card - it just confuses me when I need to use the code.
