Need help with headlight / turn signal
Hello I have a 99 boxster with the litronic headlights
I have a problem with the passenger side. The turn signal and the day time running light do not want to turn on.
I switched the bulbs with the other side and they work. I also used a tester and they light up so I guess it has to be something with the wires.
Everything else works on the headlight unit like the Xeon bulbs. the Regular highbeams ect.
anyideas? does someone have a wire diagram of the headlight ect so I can maybe see what all of these wires do...
Greg
Hey thanks for the quick reply...
Im looking at the connector right now and I cant seem to get it out as it is attached to that black part that the headlight slides into...
is there a trick to get it out as I dont want to crack and wreck anything...
