I've searched the boards, but could not find how to remove the headlights from a Boxster. My right low beam light is out and the fuse is good. So, I wanted to check the bulb. I removed the carpet from the inside of the front trunk, but I could not get any further. Any help is appreciated!
Steve
2001 Boxster, Black Metallic, 5-speed, Litronic
Get a bentley too!
Special allen tool is in the bag to assist...if they haven't been out in some time they can be a bit tricky. Be patient not to break to twist anything.
to add to the above comment - once out, then grease up the runners and locking mechanism to make them go back in easier and also make them easier to get out next time .. ;)
