The leading edge to my Cab Top has come loose. I think I have determined what the problem is. As you can see from picture "A", the left side connection, located where the windshield is, has worn down because the mating component on the Cab Top (see picture B and C) is missing a protective edge. Compare photos A, B and C of the left side (faulty side) and photos D and E of the right side (non faulty side). I think what I need to do is to replace both the part that is attached to the top of the windshield (where the sun visor fastens) and the mating part located on the Cab Top. Please confirm so I may fix this ASAP.
Loren, would you please post the part numbers? Thanks
