Hi all.
The previous owner of my 928 swears I have the correct radio (CR-210) code: 1224. When I tried to enter it in place of the C O D E message, the 1 kept blinking, but no radio started. After a few tries, I began punching other buttons. "WAIT" appeared in the window, and nothing will get rid of it, not even disconnecting/reconnecting the battery, removing/replacing the radio face plate. Of course no buttons operate. I tried the press-and-hold-TP-for-30-seconds thing, the press-the-tone-button-then-8-&-0-together thing. Nothing happens at all. There are no numbers above the buttons, so I don't even know which ones are 8 and 0.
What should I do?
(What should I have done?)
Any help will be greatly appreciated.
From the CR-210 Owners Manual (which you can download here)...
"This radio renders itself inoperative in the case of theft. If the radio or car battery is disconnected, the radio automatically disables itself. Once the radio is reinstalled or the battery is reconnected, the word "CODE", with a flashing letter "C", and the digits 1-0 appear in the display. Prior to use, the correct code must be entered via the multifunction keys.
Example: CODE 1530 (Preassigned to each radio and supplied to the owner on the PORSCHE RADIO CODE CARD) is entered by pressing the multifunction keys in sequence. (See diagram.) After the first digit is entered, the word "CODE" disappears and the number is displayed followed by three dashes. As digits are entered, the next line in sequence flashes. When all four numbers have been entered, the first digit flashes. At this time you can
overwrite the code as often as necessary. To correct any error, you must enter the complete code. Once the correct code is displayed, enter by pushing the signal seek switch.
If you have entered an incorrect code, the word "CODE" reappears in the display. The system allows two more attempts for a total of three. After three incorrect attempts, "WAIT" is displayed. A ten-minute time interval must lapse before you can attempt the coding process. You have three more attempts to enter the proper code at this time. After nine attempts at code entry and three waiting periods of ten minutes each, the radio will "WAIT" for sixty minutes. After sixty minutes, you will have three more attempts at code entry. Should you fail at this point, "WAIT" will appear, and sixty minutes must pass before you can make another attempt.
Attention: The radio must be on during the waiting period.
Note: The RADIO CODE CARD and window decals are supplied with the vehicle. To avoid unauthorized use, do not leave the RADIO CODE CARD in the car!"
Just wait a while, the system will let you enter the code again. After you enter the 4 digit code, press the seek switch to "enter" the code. That's it!
Good Luck.
  • 16 years later...
The algorithm is wrong.
The code is based on the last four numbers of the serial number.
In your example the correct code would be 2342.
24 minutes ago, new2porsche said:
I hate AI at this point.
Can someone please help me with my unlock code? 4462 x5032758
Try 2342
  • 6 months later...
