I recently had the Tequipment roll bar installed, and now do not need the rear seats. Regrettably, my installer didn't remove the rear seats, and now I'm trying to figure out how to pull them out. Any insight into removing these seats would be appreciated. Thank you very much!
locate the center plastic cover between the two rear seat backs. Pry it up from the front of the piece at the base. Locate the two plastic covers on the side brackets. They're supposed to slide down but they don't really do very well. You can generally pry then off with a flat head without breaking them. Remove all three screw with a torx driver. The seat bottoms are velcroed in, so just pull.
Let me know if there are any points I can clarify.
  • 5 months later...
