Loren,
I've got an OEM radio/nav unit in a 2002 carrera (PCM 1?). Bought used and w/o radio code. Model is BE2582 and ser#15009414. KW: 26/01. Can you run this through your magic formula for me? Is a separate code needed for the nav unit? Thanks for your help. John
Loren,
For anyone's info that's in the same boat as me.....Took it to the dealer today and for $30 they pulled both codes. In retrospect, I should have had it done preemptively when it was in for other services previously.
