My GT3 RS was delivered on Aug 14th with Pirelli tires, not the Michelin cups most seem familiar with.
Does anyone know anything about the Pirellis or how they compare to the Michelins?
Thanks.
Edited by lbp
Thanks.
I know one individual that routinely tracks his GT3 RS. I was chatting with him at Texas World Speedway a couple of weeks ago and he mentioned that the Pirellis, in his opinion, were far superior to the Michelins. He drives his RS to the track. He seems to cut respectable times - or so I hear :) Thus, it seems like the Pirellis have at least one enthusiastic and knowledgeable supporter.
Don't know/think this helps much, but at least someone out there thinks you have the superior tire.
Nestor
Thanks.
Nestor
The word on the Pirellis is that they grip like no tomorrow but wear horribly.
Flash
I am most interested in what tyres have been fitted to your car , are they the Pirelli Corsa Race or the Pirelli Corsa System
Also what size are they omn the rear, 305 x 30 x19 or 295 x 30 x 19 ??
Here is a photo of the tire sizes/model. - If this isn't enough, let me know & I'll get a better pic for posting.
...There is a mark which states (in quotes): "(102Y) NO" but nowhere can I find any reference to either "System" or "Race"
I'll look further into the tire warranty materials tonight & let you know if I find anything else.
Edited by lbp
Thank you so much you have confirmed what I suspected and the Pirelli factory have denied
I will order some straight away, the Michelins are to hard for competition unless conditions are very hot.
The Pirelli's are softer,
The Michelin have a wear rate of 80 the Pirelli have a rate of 60
Pirelli are much better in the wet the Michelin are a terrible wet and coldweather tyre and I would be very very very careful using them !!!!
I have mislead you just discovered these tyrs in the picture are Sysem Tyres , they are a great road tyre with soft compound BUT not good as a track tyre there wear rateing is aroud 120 so are substantaillt harder than the Michelin and Pirelli Corsa race I think thoug for every day use a s a high performance tyre they are great.
...Interesting. I will check the tires for a wear rating. Thanks SS.
just a point...
I was speaking to the Michelin tyre rep at a PCGB track day at the Silverstone GP circuit a couple of months back. Apparantly, they have modified the design of the Michelin Cup to make it much better in the wet; what are the build dates on your tyres ?
David
(had Pirelli's, now run Michelins )
just a point...
David
3 x sets built Aug plus set supplied on car built June 07
They are unchanged in pattern and wear rate.
Great when hot and dry ,terrible when cold or with standing water ,actually in such conditions they are leathal.
Just ordered 2 sets o custom made 18" wheels (to fit over PCCB) We will now run the Kuhmo V70A 245 x 35 x 18 and 305 x 30 x 18.
I have also ordred a set of 335 x 30 x 18 BUT not sure if they will fit. However the car will now be quicker bu a couple of secs on a 3km trach and have good dry and wet weather performance. Reason for 18", I have been informed it will be some time before true soft rubber will be available in 19" RS sizes, by some time I mean a couple of years. To remain competitive we had to go to 18". The wheels are HRE custom cup wheels made exclusively by GMG Racing in California. Got to say I am really impressed by there knowledge. Hve also purchase a custom Moton damper and spring kit from them . Have done away with PASM.
Pirelli Corsa System I have ran this tire on two different track days. My first two in fact. I would like to hear from someone who has tracked this tire and give me an idea of the tire pressures you were running and what you found. would get 5 to 8 lbs added pressure depending on the heat. I was running hot 32 front 38 rear. I was told that R compound should not run over 40 hot??
  • 4 months later...
Cold 26F and 27 R. I look for 32 F hot and 36 R . Above that pressure my GT3 RS gets greasy. Be sure you do a couple of laps to get the heat up before you push them. :)
Thanks.
Nestor
That's me.I've used the cups and found that in temps below 65 deg F they don't grip as well as the Corsas. I get about 2500 miles at a ratio of 1 track mile for every 4 road miles . I use the car only for track but drive it to and from the track. :)
What about Bridgestone?
to me they have always been the perfect middle between Pirelli (huge grip, fast wearing) and Michelin (medium grip, medium wearing)
i don't have a GT3 but a 987 and i use bridgestone potenza's on them, and have promoted them to a friend of mine who has a 996 turbo, and he confirmed :
they have also huge grip when heated a little (first corners be more careful) , after that it's grip grip grip and the tires wear VERY slowly.
try them :)
  • 3 months later...
My 2008 GT3 was delivered with these Pirelli Corsa System tires and I LOVE THEM. They are as good as Michelin Cup under dry conditions (if not better) and far better in the wet as long as there is not too much wear obviously. Probably even better than Michelin PS2 in the wet. I get them to 32lbs front and 34lbs rear warm.
I personally don't think they wear faster than Michelin Cup but they are more expensive. Now that I started to use slicks (Pirelli D3) on race tracks, I keep them for wet conditions or for DE when the conditions are uncertain avoiding unnecessary wheels changes.
  • 3 years later...
