How's it goin,
I just bought a new Cayman S and I'm new to Porsches, so I have a few questions about the aftermarket.
I want to put a limited slip differential on my Cayman asap, and I was thinking about doing a Quaife LSD. Anybody have any experience with it. Good/Bad?
Also, I was thinking of doing a Speedart stage II kit. Anybody done this yet? If so, what do you think...is it worth it?
I'd like to know what sort of 0-60 times I could expect from these two mods. If anyone has a clue (ballpark est.), i'd appreciate it.
Thanks for the help,
Reid
  • 5 weeks later...
Are you planning to track the car or is it for road use ? I doubt you will feel the difference of an LSD since the cayman has such good PSM control the LSD will hardly ever get a chance to do its job. The speedart stage 2 I assume is the ECU with exhuast mod , this will give better mid range and pick up , though for serious performance you should also be looking at new cams too. On the road I doubt you will need the mods you suggest, you would probably gain more speed and quicker lap times after a driver training day at a circuit or airfield with a professional instructor. If this is your first Porsche you probably are way off reaching the cars limits ... the instruction will let you discover both your personal and car's true potential.
